My 92 300e transmission is slipping?. Does not happen all the time. when i accelerate the trans just goes to nothing just revs like its in neutral. if i stop and put ig in park then back to drive it wont shift out of first. if i stop and restart car it works fine. pro lem intermittent does not happen all time. has done it 3 timez in last month. any ideas module or cable adjust?
W124 Moderator
Really no information here Ken other than the transmission slips sometimes. How about letting us know the last time it had a complete fluid/filter change. Miles on the transmission? Have you checked the fluid level? Fully warmed up, on a flat surface, car running in park?
Jayare
Sent from my DROID2 using AutoGuide.Com Free App
similar problem on my 1991 300e
I have a similar transmission problem on my 1991 mercedes 300e with about 150,000 miles and I am still having to deal with it. The car runs perfecly and then it won't shift. I from second into third or it just stays in neutral until I stop and restart the car and then everything is fine. I do not know why turning on and off th ignition allows the transmission to engage.:(
