I have changed the fuel filter, checked the air/fuel duty cycle (50-60%, it has moved from what I set it too yesterday which was the 42-50%), changed plugs (Bosch 4418), cleaned cap and rotor (could probably be replaced) and cleaned and serviced K&N air cleaner.
What else am I missing?
Discussion Starter · #2 ·
Pulled the K&N out and it runs great. I'll try a paper element and see if that works. The only thing I can think of is there was too much oil in the filter but I can't believe that would be enough restriction to cause the hesitation.
1991 300CE, 1992 300CE, 1995 E320, 1998 E320
Consider replacing the Oxygen sensor if it hasn't been replaced in over 60,000 miles.
