1991 420sel & 1996 S320
When I drive my 91 500SL at full throttle it shifts fine from 1-2 but when it shifts 2-3 at full throttle it tries to kick back down into 2nd when it shifts into 3rd. If I back off the throttle in 3rd it is fine.
What do you think needs adjustment? I did a search and I am not sure if it is the bowden cable.
2000 Obsidian Black Metallic Mercedes SL 320 V6
Hi jcb928 honestly the bowden cable is the first thought I have about your problem but a check at the gearbox fluids (and a change for the matter) can do no harm.
If the level is low a few shifting problems might occurr including the gearbox shifting into neutral in the worst cases all by itself especially under hard accelleration.
Hope it helps.
Cheers.
Hope it helps.
Cheers.
Should I turn the wheel towards the rear or the front? The fluids level is fine and was changed about 10k miles (07) ago.
Thanks!!!
