W212 M276 DELA 30 ; W211 OM642 ; R107 M117, W163 M112 E32
Car has 154K, and this has occurred once already warmed up on 3 separate occasions. All three were flooring it from a dead stop. If the car is already going (even only 5mph), it doesn't seem to do it. The grinding lasts about 1 second and the car continues on its way. It's not like it happens before the car starts moving, but happens as it's moving. It almost feels as though it's happening at the middle or back of the car.
I wish I could verbalize the noise.. then I could search for something other than "Grinding" which doesn't appear to yield any similar problems.
Transmission fluid is fine, oil was changed less than 1K ago. New continental tires (almost impossible for force wheelspin in dry conditions, and I know the noise wasn't from chirping, etc).
anyone have similar problems?
Almost halfway between a grind and a groan/moan.. it definitely sounds rotational (IE, if i let up on the gas, the frequency slows). I'll search for the flex disk now
Discussion Starter · #5 ·
