Blower works just fine, but heat suddenly stopped. Cold air only blowing. Thought I'd read there is a 30 amp strip fuse somewhere, but I cannot locate it. Would like to check that first obviously. Any picture or description of location much appreciated!
I think if your 30 amp fuse is blown, the blower won't work... but I'm not sure. Anyway, here's a crappy cell phone picture of the location. It's on the driver's (LHD) side just aft of the secondary firewall, in front of the brake fluid reservoir. I've opened the plastic cover (it hinges on the forward side) and you can just make out the fuse, which is is a flat piece of aluminum. It won't always look broken, but if you loosen the screws/nut that holds it down, it might simply fall apart. Easy and cheap to replace...get a few, and tape the spares inside the lid of the main fuse box.
Good luck!
Dave
