1991 300d 2.5 turbo
Rebuilt w/75k transmission - forward gears are not working, but reverse is fine. Speedo died 1 month ago and began shifting too early. Two days ago shifting was normal again, but today after coming to a stop the transmission disengaged from all forward gears. Any ideas?
- Rob
omaha, ne
Similar problem just occurred on my wife's car (91 300D). Reverse works, but no forward gear will work. Is there any obvious cause?
Thanks, Gary
Try the stage piston accessible from the side of the transmission. When they fail you lose forward gears. Cheapest thing to try before rebuild. Also when piston breaks/cracks/shatters the bar in there can drop into the pan so be ready to take it down also.
Good luck.
