1 - 16 of 16 Posts
Hey everyone. I'm new to these ol mercedes land yachts and have an issue I need help with. I have a 90 560SEL with the 5.6 v8 and have no spark to dizzy cap. Cap, rotor, and ignition coil are brand new.
The rotor in dizzy is spinning as it should. There is power to coil that I can see using a test light.
Any clue as to what I should be looking for? If there is power to the ignition coil then can I assume the control module is bad?
Thanks.
-Chris
SuperModerator
1986/1990 W126
Welcome Chris.
There's a green wire that needs to be attached to underneath the distributor. Is that intact?
Welcome Chris.
Negative. I do not see any green wire. I pulled the distributor out at one point, where does that wire come from and where would it connect? It seems the distributor has no electronics
1991 560sec. 1969 280SL
If you have spark from the coil then the problem is either a bad cap and or rotor. The button in the center of the inside of the distributor cap is probably perished.
With a multi meter do a continuity test on the rotor from center of rotor to the tip and also on the cap from inside center to the outside where the coil wire goes into the cap.
So now that I'm digging into again, it's got no spark from the ignition coil actually. Someone lead me in the right direction
1990 420 SEC
There is a link to service manuals containing diagnostic of ignition system in the stickies at top of the page. Here is the link:
I have seen and I think I have posted on this site a good YouTube video on diagnosing ignition as well.
After some testing. There is around 830 ohm resistance from the CPS so I can rule that out. Seems to me that the EZL is faulty unless my logic is mistaken
Discussion Starter #13
I'm not super fluent with electrical. I have my multimeter with setting from 200 to 2000k ohms. What setting should be used and where should the test probes be placed
1990 420 SEC
Secondary between body of the coil and high voltage terminal setting 20 k. Primary between the two male thread terminals setting 200. Primary should have no contact to coil body.
Discussion Starter #15
Secondary checks out at around 11
Primaries are a tiny but high but I have a cheap multimeter so its probably the proper resistance as well.
This all leads me to believe it's the EZL
1 - 16 of 16 Posts
