Current: 82 380SL, 83 300D, 90 300E; Former 72 280SE, 85 380SL, 89 300E, 91 420SEL, and more!
Hey all, I have a serious transmission fluid leak. The car sitting for 3 days leaves a good 1/2 quart on the ground.
But I cannot seem to find the leak. The Torque converter is dry as a bone on the outside, so its not that bolt.
I thought it was the pan because I had changed on it not too long ago, and might have mis-torqued a bolt? So I dropped it again, changed the filter again, and put in more fresh fluid. I couldnt see a drop on the pan or bolts an hour later. By the way this time I removed every spec of possible grease or crud and resealed to 8 NM on each bolt.
The pan is NOT the issue, but its leaking up above the pan somewhere.
Again this is just red, it looks like a murder scene under there after a few days.
Where might the leak source be above the pan? The dipstick tube maybe? any ideas? Anyone else have this before?
The trans shifts great by the way.
