1989 300SE, '03 E320 Wagon
Hello, I have a problem that started yesterday. The auto tranny in my wagon will downshift for no reason when I'm going aroung 60mph. If i press the gas it will then shift back where it should be. This can happen every few minutes. It seems to only do it when warm. Any thoughts? I checked the switch under the gas pedal to make sure that the carpet wasnt causing any problem....all looked well. Thanks, Mike
2013 E350 sedan, 2013 E350 cab, 1993 400E sold,1999 ML320
Bad switch, vacuum leak, bad fluid, bad filter. Need to due maint. if it hasnt been done in a while to rule out the cheap stuff.
