88 190e 2.3 8v motor. Bought the car recently and had a couple massive vacuum leaks one at the hose to the breather to valve cover and one near the cold start solenoid where the hose "Y"s to the ICV. I replaced everything with new heater hose and new fittings. Now I have a huge amount of vacuum that comes thew the breather hose that plugs into the bottom of the air cleaner, unless I manually put a restriction in this hose(used a valve stem with no guts) it will not idle just start and stall. Is there pieces missing that wernt there and I didnt replace?? Car had this issue when I bought it...NOW with the restriction the car still dont want to idle and sometime will idle at 2300. The ICV is working properly and was cleaned,valve moves correctly both ways and have correct Voltage going in and it Ohm'd in spec.
I loaded a pic(hard to see), I replaced what was there so maybe there was something missing
