560 SL
Where can I locate the window relay. Fuses are good, switches are good. No window control on either side.
1986 560-SL
Power Windows
The fuse/relay box is behind the right kick panel.
There are 2 rows of fuses along the bottom (F1 Fuse/relay box). Just above the fuses is the K4 Window Relay.
Hope this is of value,
Stan
560 SL
Stan,
Is the window relay the large relay with a 10 Amp fuse attached to the top?...
Stan,
1986 560-SL
relay
There are two relays above the two rows of fuses - the "F1 FUSE/RELAY BOX".
The "K4 WINDOW RELAY" is just above the F1 fuse relay box.
The relay that is on top is the "K1 OVER-VOLTAGE PROTECTION RELAY".
Will check e mail tomorrow - if this doesn't do it for you, will give you my phone number.
Stan
