Just swapped out to a new bottle and it is leaking where the level sensor is located. I did reuse the metal clip if that matters. What are your ideas? Thank you.
Correct, no rubber grommetIs there no rubber grommet where the sensor fits in the tank? My '79 450 does not have a level sensor, which is why I'm asking.
What kind of silicone?Plan B, for.me, would be diligent surface prep, silicone, & 24hr cure time.
No rubber grommet but there is supposed to be an O ring A0129970348. I recommend you consider purchasing the whole sensor. They wear out.,A1245400244, comes with the o ring.Correct, no rubber grommet
Yup, found it still in the OEM bottle. Geez, my bad all.No rubber grommet but there is supposed to be an O ring A0129970348. I recommend you consider purchasing the whole sensor. They wear out.,A1245400244, comes with the o ring.
Hella 1245400244, 004765041 Coolant Level Sensor; In Expansion Tank - Mercedes | 4765041 A1245400244 W01331630692
Find Hella, 004765041 Coolant Level Sensor; In Expansion Tank 1245400244 at discount prices in our extensive Mercedes auto parts catalog. AutohausAZ offers a large selection of Hella parts online. 1 per car. Fits Mercedes E320, 300DT, 380SL, 560SL, 300SD, 190E, 300E, E300D, 300TDT, 300D & more...www.autohausaz.com
