1 - 1 of 1 Posts
When I bought the car all windows would opperate except the drivers only because the regulator is bad. The motor would still whine reguardless. Now suddenly non of the windows will work or make noise except the bad drivers door, that motor still whines when you hit the switch. Fuses are still good, so I was assuming a relay but then why would the drivers side still try to function?? :confused:
1 - 1 of 1 Posts
