Hi,
We were stuck 30 miles away due to the benz not igniting. Got car towed after many hours of trying different things, car ignited after putting gas in carb area but did not stay on. We have since put jumper cable on the line of the fuel pump (under the rear right seat) and the car works then. It seems to be an electrical problem, coz when the car was down the wipers would go own by them selves...I am trying to locate (precise location) the fuse for the fuel pump relay...please help me find 87 Mercedes 300E fuel pump relay fuse, so we can replace it or resolve this problem with infinite gratitude to all that help or don't.....with infinte love, Sarita
89 300E; 00 E320
Fuel Delivery 114
K27 Fuel pumps relay Beneath right side of rear seat 248-4
N16/3 Fuel pump relay Right side of component compartment, behind battery 229-3
N16/4 Fuel pump,relay with kickdown cut-out Right side of component compartment, behind battery 229-3
looking for the fuse for the relay's not the relays
Thank you so much for your prompt response. But I was looking for the fuse for the relay's not the relays. I would appreciate all the help you can give me.:)
W124 Moderator
There is no fuse for the pumps. It's the relay as pointed out by cbc.
89 300E; 00 E320
The fuel delivery diagram 114 shows that the fuel relay is connected directly to the battery and also fed by fuse 7 in the fuse/relay box.
F1 Fuse and relay box Left side of component compartment 231-4
Fuse Circuit List 103 104
Fuse/Relay Box 102
It is there behind the battery. Black box next to KLIMA. Mine has 003 545 00 05 printed in white with a bar-code. If you wrap a paper clip or some wire around pins 15 and 87 it will get you home. (I used mine that way for 600 miles)
