1978 230 1986 300E 1989 190E
I need help with my 86 300e
On startup the car runs fine till it warms up. within minutes it goes to a rough idle and starts black smoking. I created vacumn leaks on the intake and it smooths out and runs great. As long as it has a vacumn leak it performs and idles fine.
Thanks in advance for any advice on correcting this problem.
Don
Discussion Starter #2
Well I have an update. I pulled the OVP and the terminals were corroded so I cleaned them. Now when you accelerate it loads up with fuel and sputters and will hardly move. Anyone have any suggestions?
Don
1989 300 E 96 Dodge Ram 2004 Custom Chopper 2006 Harley Heritage
Don
i WOULD REPLACE THE OVP AND SEE WHAT HAPPENS! lET US KNOW CAUSE THERES ALOT OF PEOPLE FIGHTING THIS!
Big John
The OVP is the one component that I do not have a spare as it is different on my190E, everything else is the same.
I will pick one up tomorrow and give it a try. I will post results as I have discovered hundreds of post concerning this and no clear resolution.
Thanks,
i have a mercedes benz 300e and it starts just fine but when you are at a stop light or stop at all for at least two mins it starts to shake really bad and then when you go to hit the gas it shuts down.
