1985 300TD, 1981 300TD
There seems to be several temp sending units around and on the engine. Maybe these are pressure gauges as well, I don't know. I need to change the temp. sending unit that measures coolant temp - is this the one near the glow plugs?
If you're talking the temp for the gauge in the dash - yes, it's the one by the glow plugs.
Dave aka Ghan
There's one on the front passenger side I believe by the thermostat housing that does temp sensing for the climate control unit. Is that the one in the front you're referring to on the front?
Dave
2001 Volvo V40
There is also a temperature sensor on a 1985 at the front for the vacuum control of the transmission/EGR.
