1985 300DT
I was cleaning my connections today and I noticed that when I disconnected the negative ground strap that bolts onto the firewall, the strap shares the terminal with four red wires that connect onto a single post connector.
While the grounding strap was not sparking at the battery terminal, these four red wires were sparking on the grounding post as I loosened the nut (the key was not in the ignition).
Not sure if that would indicate a short ..... anyone know what those wires ground?
Thanks!
