1 - 9 of 9 Posts
84 230CE & 84 300DT
I have an '85 300DT with 212K miles and I get a shudder that feels like it's in the driveline between 35MPH and 40 MPH. I dont think it's the automatic transmission because it does this in 3rd or 4th gears. Any one out there have any similar experiences or ideas? [?][?]
200D, 300TD, 230GE
First place I'd look is at the rubber couplings in the drive shaft!
Bruce
2x300D-83
Also take a look at the "fly-wheel damper" at the drive shaft where it´s connected to the ...
Also take a look at the "fly-wheel damper" at the drive shaft where it´s connected to the gearbox. The rubber in it maybe is about to give up.
84 230CE & 84 300DT
Thanks I'll give it a try. I had a felling that it might have something to do with the d...
Thanks I'll give it a try. I had a felling that it might have something to do with the driveshaft. I'd like to ad that there is no vibration on hard acceleration.
84 230CE & 84 300DT
Re: Also take a look at the
Thanks I'll give that a look also.
84 230CE & 84 300DT
Re: Re: 85 300 DT shudder in driveline between 35 and 40 mph
Bruce
I appreciate the suggestion I'll try to have a follow up in a week or two.
1999 SL600
any success?
Wondering if you ever tracked down the source of this problem. I'm also getting a slight shudder in 3rd at about the same speeds but usually under firm acceleration. I'm thinking transmission mount. Any other ideas?
1984 300D Turbo
check center shaft bearing.
1985 300TD Wagon
I've seen a lot but never what you discribe, there's no rubber near the darn thing, even not in your car.
1 - 9 of 9 Posts
