Ditto! bring on the gas bath!!! I pull the plug quick and let the thing drain---out of all the benzes I have owned it seems that that is the norm --last 3 though were the original lines, so i had to grind off the brass couplings to use the original fittings and put the new lines on (custom cut to fit)!NüR-SPEC said:i've done waaaay too many leaky fuel hoses on CIS cars. it's easy to overlook the amount of gas in the tank. i bet these guys are right. if not, then you may have a burt up fuel pump. the gasoline acts as a lubricant for the pump. they don't last long when dry.
So it appears I have some sort of gas leak, fairly slow. Searched the forums but could not seem to find the exact same problem. I took a pic. It is leaking from where the arrow points. Any ideas?
