1 - 12 of 12 Posts
Brown 83 300SD I have a few other projects before I get to her!
Hi all,
My 300D has been doing OK until I put the window down this morning. I went down & made a pop, not it won't go up 0r down. Motor has power & runs in both directions. Did I break the gear maybe?
I did take the panel off & have a look see but don't know how to get the motor out.
Help,
Dave
1984 300D
You are right you need to look inside and pull the Motor and the Window Regulator.
I PMed som info.
Also it would be helpful if you said what Window is having the Problem.
The rear Windows are noted for having Window Regulators that Bend; resulting in the Retulator Teeth getting badly worn.
Administratoris Emeritus
2021 SL770
More than likely, the window regulator broke, that's common enough.
Agreed. :(
It's most likely the regulator, and not the motor.
I agree as well, motor is still running it sounds like to me.
Sorry guys, I should have stated that it the front drivers door, that would have been a little more helpful.
What would I need a used regulator from Ebay if that is what it is?
Thanks,
Dave
1984 300D
Thanks,
Dave
New and new aftermarket Regulators are available.
Dorman makes some for Mercedes.
W-1-2-3 Go!
Thanks,
Dave
They didn't used to be this expensive, around only $100 maybe 3-4 years ago. But man did the prices shoot up!
Your Parts Search Returned 5 Part(s)
Hi Guys, I ended up taking the unit out. It turned out it broke off at the rivets. A dorman was like 250 bucks & a new MB regulator was over 600 bucks. The guy that I spoke w on the ph told me I could get it spot welded & that's what I did. I went over to my bro-in-laws house & he let me use his Mig. So I'm off to re-install. Just need to time up the gears after I jockey it around to get it back in the door.
I'll let you know how this turned out.:thumbsup:
Dave
W-1-2-3 Go!
I heard from a member who did the welding, that the regulator held for a year or two before going bad once more.
It was also the rivets. Are all the teeth intact?
1984 300D
Dave
I would have liked to see pics of the regulator before the repair and after!
Discussion Starter #12
Hi MBeige,
I did more than just a tack weld. If it breaks loose again, I'll grind off the welds & try again. For 28 years old, the gears are in amazing condition, very little wear if any.
Once I figure out what needed to be done it was a fairly simple job. I've never done one of these before. I must say that the MB regulator is a piece of well designed work of art. It's incredible to me how exacting these cars fit together. I expected to have to muscle it back together but none was needed. Just studied it for a long minute, hooked up the electric got the gears engaged & it went back together perfectly, didn't even break a sweat.
Very pleased w my decision to buy a W123. I fully understand how it's rated one of the top 10 cars that you can't kill & I'm very proud of her!
Dave
1 - 12 of 12 Posts
