1 - 9 of 9 Posts
'84 300D/ dakota benz trk. Sold... miss it. "88 260E '91 190E 2.6 '89 Volvo 240DL "85 300D
hey guys, my little 300d's blower motor stopped working. i can hear what sounds like the blower turning VERY slow. but there is no force at all to it. is it hard to get to? i have no blown fuse yet though. i would think that with it turning slow, bound up, that it would blow a fuse. are they expensive? can be oiled or something?
81' 300SD, 82' 300D
Now is the time to either....
A). Replace the brushes
or
B). Replace it with a new motor
1984 300D Turbo
How did you get at it? Mine has the same problem and hopfully the same fix (new brushes) Mine will not come on until I hit a speed bunp or something then turns very slow. Can you tell me how to get at the motor? Does it involve taking the dash off?
Thanks,
Mike
W-1-2-3 Go!
Hello Mike, welcome back!
Remove the underdash panel on the passenger side and have your 10/8mm sockets ready as well as philips screwdriver. It will have 3-4 bolts holding it from there. If yours has been rebuilt, there will be a Torx screw instead of an additional standard or hex type, just so you know :)
W-1-2-3 Go!
Likewise! It's getting hot here too but I already fixed mine last year using Mercedes Source's repair kit. Didn't have to remove/unbend the tabs though, and didn't cost a lot. Key is to have a steady hand so you could resolder the contacts for the brushes (hopefully it's just that).
'85 300D blower motor
I have the same problem. I've got the motor out but can't figure out how to get the brushes out. Do I have to bend the ears of the mounting bracket of the springs to pull them out. I'm afraid if I bend them they will break off.
If I just want to try cleaning the brushes and springs instead of replacing the brushes, what is a good method? Will spraying WD-40 in there damage anything, or should I just be using compressed air?
What is a good source for replacement brushes, if I go that route?
Thanks,
Chris
W-1-2-3 Go!
Thanks,
Chris
Chris,
Responded to your PM.
1 - 9 of 9 Posts
