My turn signal didn't flash so I started looking at the topic on this forum. I tested the emergency flasher switch and found term 30 and 49a open, so I jumpered them and I could use the L & R manually. Turn signal lights L & R came on but didn't flash. I need to order a emergency flasher switch.
I jumped to the relay also being a problem since I could manually flash the turn signal lights by hand. The original relay had terms 31, 49, and 49a, p/n 82109 83 or 72BK03. I ordered a new relay PA8 GF 30 and it has 4 terminals. I plugged it in with the emergency flasher jumper on term 30 and 49a. The lights would come on when I manually operated the turn signal switch on the column, but it didn't flash automatically.
Any thoughts on next steps would be appreciated. This 300CD has 262.000 miles but it is my daily driver and I really like it.
