Windows don’t work. I’ve checked the fuses and replaced with new. Still doesn’t work. I’ve sent for new control switches. What next if that doesn’t work?
R/C107 Moderator
Check the online service manual wiring diagram. I think there is a relay involved.
w108 & w107
Yes - one of the 'ice cube' relays normally located above the fuses are for windows. swap a couple of them around to see if you can get the windows going.
