1 - 9 of 9 Posts
CJ,300SD,SJ,TDIJett
Dear Experts,
Our pristine little beauty, '82 380SL, appears to be running a little too rich but I think it's more than that simple.
It smokes black heavily when it's started cold, also smokes bad when it's hot if I rev up the rpms in park or neutral - not that we do this.
We chanaged the injectors, frequency valve, oxygen sensor and prior to that the spark plug wires and plugs.
There's no freon in the a/c system if that makes a difference.
Thanks, Aleks
Always Remembered RIP
Possibly worn valves or seals allowing oil to enter the head.
As a general rule black s...
As a general rule black smoke is usually oil, blue is fuel and white/clear water.
350SLC, 500SLC, 300TE, 190E2.3 Sportline
Re: Possibly worn valves or seals allowing oil to enter the head.As a general rule black s
Black smoke is usually rich fuel mixture. Blue is usually oil. White can be water or very bad oil problem, among others.
CJ,300SD,SJ,TDIJett
Black Smoke -380 SL
Dear Benz Brothers,
We found the problem to be the warm-up regulator[:O].
It's the aluminum device staring you in the face at the front of the engine just left of center.
[:D]She is running smoother than smooth.[;)]
The component was about 550 USD. Let me know where I should be getting our parts if you will?
Aleks
Windsor, Ontario, Canada[;)]
CJ,300SD,SJ,TDIJett
black smoke - 380 Sl
Thank-You Benz Brother HECKFLOSSE.
found it to be the "warm-up regulator"
Aleks
black smoke
I have replaced just fuel distributor, spark plugs, fuel pumps, OEH valve and still get blck smoke after a while may be 15 miles. Any sugestions. In the morning the car smooth as a baby's a.. but after 10 to 15 miles black smoke develops at all speeds. I am contemplating to replace the O2 sensor. Any sugestions?
Thank you
Aleks,
GERMANSTAR .... I paid $225 plus a core charge of I think $25.00. Plus shipping of I think $25. All US funds. To Barrie Ontario. The dealer wanted $1250.00 and my first born.
87 300SL "Roadster" 86 420SEL "Limo" 89 420SEL The "New" Limo 87 190E 2.6 fact bodykit
Thank you
It would help if you say what model you have. I had a similar problem.
As above try the cold start injectors and check your fuel for contaminants like rust or water.
If I had done this first it would have saved me a fortune.
Good luck
1 - 9 of 9 Posts
