A friends family had a 82 300sd in the garage. It had sat for about 8 years, been driven minimal for about 5 years prior. It's got 145000 actual miles it. I replaced the battery and it started right up and drove 30 miles home. It's a beast! Was thinking of doing the oil, transmission, differential fluid and putting some anti fungal/fuel additive, and air filter. Fuel filter at some point. Any other ideas on major or minor stuff I should do immediately and what other things I should try to do?
1981 W123 300D non turbo, 1992 190E 1.8 <=> 2.0
I would =>
Check the condition of your tyres!!!
Then
engine oil and filter
coolant
transmission oil and filter
differential oil
brake fluid
power steering fluid and filter
fuel filters
air filter
clean check and adjust front wheel bearings (for the rear you have to hope for the best really as they are difficult to get to)
check for oil in the axles
Most importantly though check the overall condition of the car. Don't just limit yourself to the mechanical components. Look at the water drains and the rubber seals and make sure there that water isn't getting into the car. W123s can rust and rust and rust. I think that rust is the number one killer of these cars.
After driving for a few weeks I'd change the engine oil and filter again.
^ Good points all.
If it's an SD, that makes it a 126 chassis, check on that forum section.
Smart eyes there - SD indeed!
Dag nam it - I only ever post on the W123 forum - it looks like I'll be moved...
Discussion Starter · #5 ·
Owners manual said w126 and just didn't look far enough down. I'll start working on this stuff mentioned. Tires were ok actually. Maybe down to 1/2 air but not really dry rotted that I can tell. Super neat car.
1984 300D
Check the Rubber stuff:
Oil Cooler Hoses
Transmission Cooler Hoses
Drive Shaft Flex Discs
Drive Shaft Bearing Support
Rear Axle Boots (they are filled with Oil at the Factory cracks can lead to lubricant loss)
Motor Mounts (on the W123s when the left side Motor Mount gets squashed the Power Steering Belt has been known to cut through tha Oil Cooler Hose)
