1 - 1 of 1 Posts
My 300sd currently blows white smoke from the tail pipe and oil cap while idling. I also noticed oil leaking around the front of the motor and the side where the injectors are located. I removed the top off of the air filter housing and their was also oil build up. The oil in the air filter was coming from the tube that connected the air filter to the motor. What could cause all this? To me it sounds like a bad head gasket or piston rings, but i really dont know. All info is helpful, im new to diesels.
Thank you
1 - 1 of 1 Posts
