1982 300CD, 2000 Audi A4
I have a 300CD that I've been slowing getting back on the road for the passed 2 years, and it has always started and ran fine (except every once and awhile it wouldnt shut off untill I pressed the manual shut off). Untill recently, now it will start no problem then in about 30 seconds will die out, I think it is perhaps a wiring issue but I am in need of help.
1979 280CE
Its not a wiring problem.
Sounds like air is getting in the fuel system. Inspect the system for leaks. Does the primer pump leak diesel when you pump it?
