81 300SD
OK New fuel filters, glow plug and full tank of fuel. Car turns over but wont start...Its started once and died 2 seconds later. New air filter installed...does it have to be oiled? If so please give me a link.
Check the primary (clear, in line) filter for fuel or air.
Be sure to prime the new spin on filter full of fuel.
If you have a paper filter, don't oil it.
1991 300 SE
You need to loosen, not remove, the canister filter and use the hand pump to purge air from the system. First you’ll get bubbles then fuel will come out of the top of the canister filter. Tighten the canister filter and start. Just put a fluid drain pan under the filter to catch the fuel.
81 300SD
Thanks fellas..thats fine changed all rubber since I'm at it and nodda. I'm gonna work on strainer at gas tank because I dont think I'm getting fuel. I'll change all those lines while I'm at it. Any tips on cleaning the tank without dropping it?
