Discussion Starter #2
You will need a SAFE jack and jackstands, most important.<br> <br> Then you will need a screwdriver to loosen the emergency brake star wheel through a lug bolt hole then an allen wrench to remove the bolt holding the rear rotor in place. You will also need a stout ratchet and socket to remove the caliper bolts. Pull caliper out of the way and wire up to prevent strain on rubber line. Replace rotor then put caliper back in place. Remove and replace the pads one at a time, or you risk pushing one of the pistons out too far which will require complete rebuild or replacement of the caliper.<br> <br> Good luck,<br> Larry
