1 - 17 of 17 Posts
Non MB 1975 Volvo C304, 1958 Kramer U540, 1959 unimog Westfalia 411
I have 8 hole wheels on my Kramer, the 20mm studs are 275 mm across and the hub is 220 mm. Does anyone know or have the specs on the unimog 8 hole wheels. These axles were used on 80 hp tractors and front end loaders. Its a massively heavy portal assembly, the axle turns a small gear that turns the hub through the bull gear which is supported on either side with multiple bearings. If I could get it on my scales I would but its heavy enough to be dangerous. The crazy part is the amount of disassembly to access the brakes. the PO torched a bracket to change wheel cylinders and the guy from germany scorched me for circumcising the part (his words). The goal is 24" wheels that I will most likely have custom centers made, and some treads like sold by superior traction.
Thanks, interesting bit I did see that my drum has the 221 mm opening. Searching had not yielded that post. thanks again!
Thanks sdo. I had struck out using the search function. Food for thought maybe I need to find a set of mil bead locks and put new centers in. Please share pics of your endeavor.
1963 404 TLF-8 MB Type A PTO Winch (sold)
Here is your one stop shop for everything military... scroll down the page and on the left hand side is a search function by state.
Search Results - Government Liquidation
1983 U1200 (parted out), 1979 U1700L
Here a two quick pics of the progress. I am doing the work at friends machine shop, Glacial Pace Machine.
First pic is machining the Center out of the MRAP wheels with the CNC mill, second pic is of the new centres, centres still need to be turned down to 15.5" od and have a shoulder cut in them.
Machine Gear shaper Machine tool Auto part Metal
Discussion Starter · #9 ·
Ditto, thanks for sharing. LPG I do look occasionally for stuff being sold up here, I haven't seen any wheels yet. I know we have a few SEE units up here that should be due for sale.
U-406/416
So this unit your working on is basicly a planetary axle hub? But is sound diffrent with only one bull gear. Instresting!
Dose it change the center line of the wheel like a unimog portal axle or dose it stay in line like a planetary axle?
Discussion Starter · #11 ·
The axle enters the top of case and drives the large gear. Here is a pic of the housing apart (not mine). These units are very heavy duty. Tow rating of 40 tons and a 4 cyl deutz with about 40 hp to drive it.
Auto part City car
· BenzWorld UNIMOG statesman
Unimog 404.1 Diesel (sold :( )1995 LMTV 1078, 1995 M1079, 1079box for sale !!!
Somethings up. I edited several post in here cause the pic would not show up. Had to manually embed the attachment. Still they only show up as a link to the attachment though
1 - 17 of 17 Posts
