-1985 300d (champagne/palomino 133k) -1979 300d (dead parts car)
does a 1979 300d use the same flex pipe as a 1985 300d?
is there a way i can look this up myself so i don't have to post a question?
thanks in advance,
jds
81' 300SD, 82' 300D
thanks, yall! too bad, as that part is $122 on az. oh well, maybe i can tack the holes myself.
thanks, htown. joined the epc! now i just gotta figure out how to use it :)
W-1-2-3 Go!
Yes. Get yourself a subscription to the EPC. You'll be able to tell whether the parts are the same or not.
EPC-net Online
On top of this, there's this site, which allows you to view Euro models as well. Just a bit trickier to navigate.
If the link doesn't load, go to ????????-??????? ????????????? DETALI.RU - ???????? ??? ????? ????????. and click on the Mercedes-Benz link on the LEFT margin. It will pop up a window with the address of the link posted above.
The Russian EPC has its own limitations too. Feel free to look up either one.
Non turbo 300D
Turbo 300D
'85 Turbo CA versions probably had a flex pipe that's higher.
