This concerns my very clean 1976 R107 SL with just 107k miles. The RED brake WARNING light is now illuminated on the dash. This warning light came on when brake pedal traveled almost all the way to the floor and had to be pumped up. Once pumped up the pedal remained firm and the car seemed to stop properly except for a hard pull to the left. This pull went away after applying the brakes a few times and the still firm (normal) pedal stayed present. No brake fluid is leaking anywhere; the master reservoir remains full of fluid to the max mark. I drove the car a few times and the brakes functioned normally except for the warning light still remaining on. Then about a week later the brake pedal went near the floor again. It pumped up nicely again and it has held for about 4 months. Right after that 2nd time, I decided to change the very dirty brake fluid present in the reservoir. Using a turkey baister, I sucked the old fluid out of the master's reservoir and replaced it with fresh fluid. A few months passed and the car has only been driven a dozen or so times since the 2nd drop of the brake pedal. The pedal still remains firm but the brake warning light is still on.
I purchased this car only 3 months prior to all this happening (about a year ago now). Prior to the low pedal and warning light, I thought the car was somewhat of a slug, it lacked power. It felt like it was very heavy but having never owned a Mercedes 450SL or really ever driving one much prior, I had no idea of how it should really have felt. Since the to the floor (almost) pedal issue occurred the car now has nice power, it appears the brakes used to drag prior to the dropped pedal. I am confused because I never smelled that brake burning smell that should have been present if the brakes were dragging. I drove about 1000 miles(mostly 6-10 mile trip)s prior to loosing the brake pedal, I did take the car on the freeway a few times so if the brakes were dragging a burnt brake smell should have been present.
Is this a failing master cylinder???? What else to look for???
