I recently bought a 1976 450SEL with over 200k miles, although the true mileage is unknown because the odometer stopped working a while ago. The car needs to be warmed up for at least 15 minutes before the car goes into reverse. After that, it works fine. If the car is turned off after several hours, then it must be warmed up again. The car shifts smoothly in all gears after it's been warmed up and seems to be normal besides that. Is this a major transmission issue or a quick fix?
1999 E320, 1975 450SEL, 1979 280SE
Well, if you don't know when it was done last, I would start with basic trans fluid and filter change. It could be that the fluid level is a little low. Trans fluid expands when warm. It should be checked when warm, with engine running, in Park. The car should have been driven before checking fluid level. Since it seems to work well when warmed up, I don't think that it would be a major problem with the transmission. Start with the basics. I hope this helps. Best regards, Peter
