1 - 8 of 8 Posts
Don't need/want the AC in my "75 240D and am curious if there are any potential issues, vacuum loss etc if it is taken out.
I'd like to remove the compressor and condensor but avoid fishing all the lines out.
Thanks I hope
David
2003 Mercedes Benz E500
One small question...
Why?
If the A/C is not running, the clutch on the compressor spins freely, so there is no loss of economy [and I DO note you are a diesel owner].
Granted, the car is not exactly a hot rod, with or without the A/C, but a subsequent buyer may want that feature, which may not necessarily add value, but will make the car more marketable.
Inquiring minds want to know...
JR
JR
If it helps you to answer my question or just ease your curiosity, I'm not concerned about subsequent buyers, the car is not for sale.
I live in Seattle, when it's nice I roll down the windows and enjoy. The front of the compressor pully rattles with belt attached or not and with AC on or off. That bugs me. Dragging around any unecessary weight and working around it for maintenance and repair also bugs me.
If removed it wouldn't be discarded anyway.
So back to my question, yes, no, do, don't?
Regards
David
Administratoris Emeritus
2021 SL770
You can safely remove the compressor and condenser without impact on the rest of the vehicle.
What he said...
Additionally I would carefully plug the hoses so no debris or moisture can intrude into the other A/C components and also secure them so that no rattles, noise or damage can occur. That way, should you decide to re-install the A/C you will not be looking at replacing any extra parts.
I suspected that it also had something to do with the extra weight. I know that "diesel doods" march to the beat of a different drummer. I once sold a diesel wagon to a dyed-in-the-wool diesel guy, and his first comment was along the lines of removing the roof rack as doing so might get him an additional 1/2 MPG...
Good luck on the project.
JR
1973 W115 200 /8
You should be happy it's a diesel.. The diesel's have lower ratio on the rear axle, compared to the gasoline-cars.. (So I've heard..)
Thanks guys!
I'm in the middle of other under hood issues and thought about this, not really a MPG issue, I drive about 3 miles to the train and hop on it to work.
It's basically my urban tractor.
As far as the lower ratio, it was also built in the era of the nationwide 55mph limit so it doesn't care for too much above 60, but 1st gear is a stump puller.
Regards
David
1 - 8 of 8 Posts
