1 - 1 of 1 Posts
73 450 SL
I have problems with the heat doors (his/hers) they were stuck down when I bought the car. I got it all apart and found the original foam had deteriorated, when I cleaned the foam off doors they seemed to work ok, I couldn't find any foam so I used felt of the same thickness, the doors worked fine untill I assembled the lower box onto the unit, the right one works, but the left one worked 3 times then stuck down again. Anyone know where to get the original foam or how to correct this? I'd like to get this back on the road. Thanks Rick
1 - 1 of 1 Posts
