1 - 20 of 24 Posts
Did somebody change transmission oil on ML320 2008? Please advise on the following: Where filling plug is located? Thank you
You fill it from the drain plug. You will need a pump to pump the fluid into the pan. On the inside of the pan there is a plastic tube that fits onto the drain hole. the colour of this tube indicates at what temp to check the fluid level at. The most common colour I have come across is white which is checked at 45 deg cel. Once you fill the transmission hook up a scan tool that is capable of checking the transmission fluid temp. At the corresponding temp you remove the drain plug and let the fluid drain out until it is just dripping. At this point the transmission is filled to the correct level and you replace the drain plug.
If you are just doing a filter change just pump 5.5liters into it and your level will be correct, I am a 15 year master Benz tech, do these daily
I have a 2008 ML 320 CDI with 42,000 miles on it, and want to change the transmission fluid and filter. My research has resulted in all kinds of confusing crap.
1. Is there a new oil pan that is sloped, with a white overflow tube that replaces the old pan and black tube? BT27.10-P-0006-01W. "Oil pan and overflow tube modified" for 722.901.
2. M-B dealer service rep tells me there is no such new pan and tube, and that a transmission service costs $355, and includes only 4 quarts of M-B fluid (@$34per quart!) and a new filter. He says they do not drain the torque converter. I know this tranny holds 9.5 quarts and this makes no sense to me. He says there is no way to drain the torque converter without using a flushing machine and about 20 quarts of oil!
3. An independent mechanic says that Chrysler ATF +4 from AutoZone is ok for this tranny, but I can find nothing that says it meets any M-B spec, as opposed to
AMSOIL which says it meets the M-B 236.1 and 236.4 spec.
Who the )(*&*(&%^ do you believe. Can anyone blow the smoke away from this nonsense?
W220 Moderator
per SI00.40-p-0014a
722.9 serial number up to 2834526 use 236.14 spec. red fluid, white tubed pan
722.9 serial number as of 2834527 use 236.15 spec. blue fluid, green tubed pan
Might point your Dis-Service Advisor to AR27.20-p-0200-03r for torque converter draining.
American refiners on 236.14 are Mobil ATF 134, Shell ATF 134, Valvoline Synpower ATF 134
American refiners on 236.15 are Shell ATF 134FE or Shell Spirax S6 ATF 134ME
Per SI27.56-p-0001a
Oil pans without beveled edge and black pipe must be replaced by new parts in order to be able to install new filter.
oil pan w/ bevel a221 270 09 12
overflow pipe ( white ) a251 271 00 97
2 magnets a000 988 01 52
That help any ??
As others have said you pump the ATF in through the oil pan drain hole and it uses the overflow method to set the level. I did my own 722.902 service on my 2008 W204 C320CDI and the transmission runs like a Swiss watch now. I improvised and came up with my own very simple and quick method to pump the fluid in. You'll have a TC drain plug I'm sure.
I even flushed new ATF through the oil cooler so my job was very thorough.
I used between 8.5 and 9.0 litres of Fuchs 4134 ATF. You will probably have the white overflow pipe and already have the beveled pan so 45C will be the temperature. I used the temperature probe on my digital multimeter taped to the bottom of the oil pan with some insulating foam over it. You don't need the software to measure the ATF temperature. I won't get into degrees of accuracy and methods of measurement but when you set the level by overfilling slightly and then draining the excess until you get a "spitting intermittent flow" is subjective to say the least. The proof of the pudding is in the eating and my transmission is running like a new one using the method I dreamed up.
I made a video of the job: https://www.youtube.com/watch?v=_-72EN_pqUU
per SI00.40-p-0014a
Per SI27.56-p-0001a
That help any ??
It helped a lot - thanks.
per SI00.40-p-0014a
Per SI27.56-p-0001a
That help any ??
I've read Per SI27.56-p-0001a. I called my local dealer parts to inquire on the new beveled pan. I was told my non beveled pan is correct and there was no change according to my vin for the 922.901 transmission.
The torque converter can be drained by letting the starter go up to 200 RPM and this will drain it! Definitely do not allow to start the engine!! You are correct to say the total is about more than eight litres and mixing old and new oils is not good. Four quarts is absolute rubbish! Please look up the new auto oil specification called MB 236.14 and you will find all the oils Merc recommends, such as Mobile ATF 134, Shell ATF 134, Shell Spirax S6 ATF 134M and many more including Valvoline, some in the USA sell for US$5/quart!! DO NOT GET RIPPED OFF! I have read most Merc auto trans oil change recommendations on Google and I suggest you do the same.
2008 CLK63 - same thing, just pump in 5 liters and be done? All I have done is take the tranny pany off, and I will be replacing the filter. Nothing more.
Oh the tranny pan is plastic, flat, with small dimples and the drain tube is (was) white.
Thanks.
Hi,
Thanks for info for a 722.9 box. To quote a precise figure for the oil change is interesting as on my 722.6 box, there are probably more than a few pints of oil always left in the torque converter and unless you use a flushing machine, you can never get all the oil out as a DIY mechanic.
One chap suggested turning over the motor via starter to 200 RPM BUT definitely no starting to get all the oil out of the torque converter??
Can a 722.9 box really be emptied completely to quote a refill figure?? All I can suck out of my 722.6 box is 3.5 litres, might be 7 pints? Then I fill the same amount in again, drive a bit and suck out another 3.5 litres and do it all again. Oil is never quite red as it should be as it mixes with the old "black" stuff.
Help!
Hi,
Help!
I have the 722.6 5GTronic in my 2006 W639 115CDI Vito van. The TC has a drain plug and holds about 50% of the ATF. To do the total change including flushing the transmission cooler is about 8.5 litres.
For information I've been using this ATF (meets MB236.14) in my 722.9 and my 722.6 which both specify MB236.14:
https://catalog.lubricants.total.com/en/products/9rv/FLUIDMATIC-MV-LV
Does your C220CDI not have a TC drain plug?
I made a DIY video which is relevant for the W204. The only difference I suspect would be you won't have an external thermo valve in series with the oil lines to and from the oil cooler. I would take a guess it would be the same as the 722.9. You have a line coming from the transmission straight to the oil cooler and return line back to the transmission. Those lines and oil cooler hold about a litre so why not get rid of that old oil? You'll be able to flush in one step.
I find it interesting that transmission service instructions in the older WIS document for the 722.6 in my Vito says to flush the lines to the thermo valve and the lines from the thermo valve to the oil cooler. The WIS also says to drain the TC and the transmission thus changing 99% of the ATF.
Over the last ten years Mercedes dealers have "progressed" to the point they only change 50% of the ATF! Will they soon be only changing 50% of the engine oil!
The only explanation I can dream up is Mercedes make transmissions. It's not in their interests for our 722.6's or 722.9's to last. They want to sell $10k transmissions when they fail early due to "filled for life" nonsense or 50% servicing.
"Additional Oil Cooler"
Hello guys,
My 2007 ML 350 is making some strange clicking noise after starting a cold (only) engine and goes right away. (keep in mind i have changed the fluid once because of the bad balance shaft replacement).
I decided to take the valve body off to take a peek if there's anything mechanically wrong. I'm placing everything back in and getting ready to replace the fluid.
HERE'S WHERE THE QUESTION IS:
The instructions call for 3 different temperature ranges when topping off, 35°C, 45° or 90°.
35 for "without additional transmission oil cooler and without chamfered pan"
45 for "without additional transmission oil cooler and with chamfered pan"
90 for "with additional transmission oil cooler"
What are they talking about? is the "additional" additional to the stock cooler? or is the "additional" is the actual stock cooler?
last time i topped it off at 45°.
thanks,
1 - 20 of 24 Posts
About this Discussion
13 Participants
IWantedaJag
Mercedes-Benz Forum
Full Forum Listing
