Hi all,
I have a 2010 GLK350 with ~146k miles. I believe it has the early 722.9 revision with red fluid. I noticed the car clicks and binds when turning the steering wheel hard left or right. At first I thought it was the CV-axles, but those were fine. I jacked it up and found about half an inch of play in the front driveshaft where it meets the transmission/transfer case. After doing a little research, I believe I found the part that needs to be replaced but I think theres a lot of obscurity of the parts' availability and reparability. I wanted to ask if there was a place I can purchase this part from a well-known site/place, or potentially repair it. I see that there is an internal u-joint, however I am not sure if that u-joint is replaceable via snap rings or if its welded as one unit.
From what I researched online, it looks like I can replace this part without taking the whole transmission out, which would be a huge advantage and time saver
I appreciate everyones time for reading this and any advice you can give. Please dont tell me I need to replace the whole transmission, Im only asking for information on replacing/repairing this part. If all else fails, I know I will have to replace the transmission.
