1972 280 SE 4.5 V8
My 1972 SE 280 4.5 Gas powered V8 is having some transmission issues. The mechanics are having a hard time sourcing parts so far and quoting me between $2,500 and $5,000 to rebuild. I'm wondering if there's a transmission swap I could do with a different model/make that would be less expensive.
Or, is there a parts supplier to provide more reasonably priced parts for the 72 transmission.
I searched the forums, but did not see a topic specific to transmission swaps.
Charlie
71 300SEL, 16 BMW Z4, 58 MGA, 80 Triumph TR7, 85 Porsche 911
$1500 for a rebuilt is a good deal. I paid about $2500 through Aamco, back in 2005. Is this quote from a mechanic? Or from a transmission specialist?
1972 220 D, 1974 450SL, 1995 E300D 2002 S430, 1976 300D, 1986 SDL, 1982 SD
You are getting reasonable quotes for rebuild/repair. Even if you find the adsit rebuild, you are still on the hook for a number of hours shop time. Comes to $2500-3k.
One very good option is to tear it down yourself and do the part replacement on your own bench. Should run $300 for parts. IF you have access to junkyard cars, you can source the transmission from a R107 (73-75) or the w114/115 after 8/73. W116 will have the same transmission. 3 speed with torque converter - W3A 040
Not to steal the thread, but I wonder if there are outfits that can produce adapter plates and such to hook up a non-Benz tranny. That poor three speed really sings at highway speeds. I'd love to find something to bring the revs down - maybe a chevy 5 speed OD...
anywhere from '52 300 to 1990 560SEL,and a '93300TE nothing newer, too much trouble....
How about a shorter ratio rear axle .
I may have one.
Depending how healthy your motor is.....
