Mercedes GE300
HI from Italy,
I'm looking for the gear ratio of this shifter 717.466, it was mounted on c220cdi and 290TD i suppose
Now I have a 717.439 install on a G class m103 motor, the gear ratio is too long for my use. So I'm looking for a shifter that has the same bell clutch like the 717.466 but with a shorter gear ratio
my Fifth gear ratio is 0,8 (overdrive) I want a fifth gear ratio like 1 (direct connetion, the same rotations of the motor shaft)
The problem is to found on internet the gear ratio of this transmission
Giacomo
I have 717.466
210 26008 00717 466 0 .7283801
I do not know the ratio refer to above number however I am in San Francisco California
Moderately subtle
94 E500, 97 500SL
Just so's we're all clear, here. This is the W202 AMG section of Benzworld. If this gear box isn't for that car, the likelihood of getting an answer to the question here is very very low. Each of you should find the Benzworld section that is specific to your car, getting an answer is far more likely.
