Hello all, I am in need of some serious help!! I have been restoring an 66 230S and have an issue with it running. It will start and idle beautifully, but after I drive it for approx 2-3 miles it dies! It will start right backup, but will die when put into gear. I have had the Zenith carbs rebuilt (but I think this is where the problem lies), and have replaced all ignition components. Please HELP!!:confused::confused:
1967 250SE (W108)
It's a long shot, but it could be a fuel filter. My buddy had a similar problem.
It would run for a while, then stall. After sitting a few minutes, enough crud must have fallen from the filter to allow fuel to flow again for a few more miles until it clogged again and stalled.
Good Luck,
Klaus
1965 220S, 1999 Volvo V70 (wagon), 2006 Ford Crown Vic Police Interceptor, 72 350SL 4 Speed
Also check the screen in the tank. It's on the bottom of the tank in the middle and has a large hex hole in it. Get a new one from the dealer, two nuts and a bolt to fit.
