1 - 13 of 13 Posts
60,000 Mile Service
I got the Underside of car and Wheels tires & brakes complete. It took me 9hr just to do that, I'm getting old.
Total cost for parts ~ $400.
All Models
 Brake test, parking brake check …………………………………………… 4290
Interior
 Check warning indicator lights and horn ………………………………… 5451
 Clean cassette deck tape head …………………………………………… 8230
 Inspect headlamps and exterior lamp …………………………………….. 8251
 Inspect/test windshield and headlamp wiper washer system …………….. 8252
 Inspect Seatbelts for damage ……………………………………………. 9150
Body
 Lubricate door hinges ……………………………………………………. 7220
 Lubricate door locks …………………………………………………… 7221
 Clean antenna mast ……………………………………………………… 8252
 Check condition of headlamp wiper blades …………………………… 8252
 Replace windshield wiper inserts ………………………………………. 8280
Wheels, tires & brakes
 Inspect and rotate tires ……………………………………………………. 4050
 Inspect tires and record tread depth …………………………………….. 4051
 Correct tire pressure ……………………………………………………. 4060
 Check brake pad/disk thickness, check condition of disks ………………. 4251
 Adjust parking brake ……………………………………………………. 4261
Underside of car
 Inspect condition, routing, leaks, of components, lines and hoses ……. 4050
 Check and correct rear axel fluid level ……………….…………………. 3510
 Check front axel ball joints …………………………………………….. 3353
 Check steering play …………………………………………………….. 4650
 Retighten steering gear bolts …………………………………………. 4671
 Automatic transmission fluid and filter change ………………………………. 2702
 Inspect drive shaft flex disks ………………………………………………………….. 4152
 Inspect parking brake cables …………………………………………………………… 4256
 Replace fuel filter ………………………………………………………………………. 0780
 Replace O2 sensor ……………………………………………………………………… 1480
Engine compartment
 Inspect condition, routing, leaks, of components, lines and hoses ……. 0053
 Engine oil and filter change ……………………………………………. 0101
 Check condition and tension of V-belts ……………………………….. 1350
 Check spark plugs and replace as necessary …………………………… 1550
 Replace spark plugs ……………………………………………………………………. 1550
 Check and adjust engine coolant level and protection ………………… 2010
 Check and adjust automatic transmission fluid level …………………… 2710
 Check and adjust brake fluid level ……………………………………… 4210
 Check and adjust power steering fluid level …………………………… 4611
 Check and adjust battery electrolyte (if battery is under hood) ……… 5410
 Check and adjust Ac refrigerant charge ………………………………… 8312
Trunk
 Check and adjust battery electrolyte (if battery is in trunk) ………………….……. 5410
 Check and adjust spare tire pressure ……………………………………. 4060
Always Remembered RIP
1979 280sl 4 sp w/ac 1957 MGA 1998 volvo xc/70 2004 F150
Hell John, I havn't even checked my tire pressure
1987 Mercedes-Benz 560 SL
60,000 Mile Service
Holy cow, John. Obviously "check", "inspect", and "adjust" are a bit more involved process for a man with your eye, talent, and experience.
I try to be thorough, but ignorance is a great time-saver, it would seem. :bowdown:
Good road,
I used to do this on a daily bases at the dealer 22 years ago. Took about 4 hours for the whole job. It's a combination of age lack of work area and lack of equipment.
OK
I finally finished it and completed all the paper work. True cost of this job ended up being $540.00 with the only non service related parts being a rear view mirror and 2 shifter bushings. I replaced all parts shown in the 60K service below and optional belts and filters. Most of these parts were genuine MB and came from Parts.com, plugs, filters and belts were OE manufacturer and came from AutohauzeAz.com, O2 sensor was OE Bosch and came from Europartsdirect.com. Mobil 1 oil and Castrol ATF came from local parts store. All this stuff from MB dealer would have cost over $1000.00.
Now done with that. Done servicing all other cars for the winter or until next catastrophe. The lift is clear, back to Samson.
PARTS REQUIRED
The parts and fluids listed for each service are required replacement parts and fluids. The technician should also have on hand the following fluids for top off as required as well as spare bulbs listed on the last page.
Engine Coolant Q 1 03 0002
Dextron III ATF
Dot 4 Brake fluid A 000 989 08 07 10
Universal hypoid gear oil, SAE 85-W90 A 001 989 17 03 10
Door lock and latch grease Castrol CLS grease
Windshield washer fluid
Windshield Washer Concentrate A001 986 80 71 17
Power steering fluid A 000 989 88 03
Battery electrolyte N/A
Every Two Years
Every Three Years
15,000 Mile
9 qt oil
Oil filter kit A 000 180 06 09
Rear Axel Seal N 007603 024105
Antenna mast cloth
Wiper inserts A 000 824 18 27
30,000 Mile
9 qt oil
Antenna mast cloth
9 qt Dextron III Transmission Fluid
Transmission Filter A 126 277 02 95
Transmission Gasket A 126 271 10 8 Torque = 8N/m = 71 in-lb
Transmission Plug Copper Ring N007603 010112 Torque = 14N/m = 124 in-lb
Converter Plug Al Ring N007603 010100 Torque = 14N/m = 124 in-lb
100mm x 7.5mm cable tie
8 spark plugs Bosch W 9 DC or W 9 DP
Air Filter A 001 094 78 04
60,000 Mile
9 qt oil
Antenna mast cloth
Transmission Gasket A 126 271 10 80 Torque = 8N/m = 71 in-lb
Transmission Plug Copper Ring N 007603 010112 Torque = 14N/m = 124 in-lb
Converter Plug Al Ring N 007603 010100 Torque = 14N/m = 124 in-lb
8 Spark plugs Bosch W 9 DC or W 9 DP
Fuel filter A 002 477 17 01
2 Fuel filter Copper Ring N 007603 012110
O2 Sensor A 007 542 52 17
Optional Parts
Air Pump Filter A 002 094 46 04
PS Filter A 000 466 16 04
AC Belt A 004 997 05 92
Alt Belt A 009 997 53 92
Air Pump Belt A 006 997 24 92
2 PS Belt A 005 997 95 92
2 Engine Block Drain Al rings A 636 997 02 44
Niiiiice,
where did you get the info from? I mean, do you have a book or sthg you can post that says: at X miles check A-B-C, at Y miles check... etc.
I wish I had that!
Thanks in advance.
It's all in the 107 CD but I added the part numbers.
1979 280SL, 1984 280SL
So, John- After all that it must feel pretty good going down the road, knowing your 560 is ready for anything!
Excellent work, Mr. Roncallo. :thumbsup:
Good road,
Discussion Starter #12
Ready for anything???
The 60K service does not include replacement of all under hood fuel lines, R&R and reseal of steering box and flex coupling or replacement of all cooling system hoses and leaking radiator. It merely includes pointing those facts out to the poor bastard customer, ME:D
Those are the last of the mechanical items, in need of service on Delilah to bring it to 100% mechanical condition. I do hope to get to these within the next year. Two of three fuel lines are already on order. My main concern after the fuel lines is the cooling system hoses. They have not been replaced as long as I have owned the car 6 years, and I have no prior service history.
1 - 13 of 13 Posts
