81 - 100 of 163 Posts
75, 280Sl /5speed
Just to throw another ingredient into the pot, M275, twin turbo setups, show up on E-Bay once in a while.
yet to be determined
Discussion Starter #82
forced induction was off the table from the get go, we wanted to make the power naturally
Discussion Starter #83
so..keep this in mind ALL wheels seen untill told otehrwise are purely for MOCKUP ONLY and to verify sizes not even offset numbers, tho general placement outside the body is probably close to the finished reality
Discussion Starter #85
alot of serious debate of 17s vs 18s and 19s, at this point we know 17 is too small for the body, 18 is good, 19 is still on the fence but ONLY for the REAR 18s will go on the front
fenders are marked for a few things, 1 so me and the owner can talk lines, its much easier with each major line numbered, 2 engine and suspension placement, 3 cutting lines
Discussion Starter #86
the rockers were considered to get cut clean off the car but after ALOT of measureing and re-measuring and tripple checking, it looks like they will stay but get heavily modified as they roll under soo sharp they give the car the apearance of being a mile off the ground
Discussion Starter #87
a few suspension rough mockups before i found the only easy way to make this happen was to make new rails
Discussion Starter #88
more wheel works, and btw thats a 305/19 stuffed under the rear of the car, the double barrel no face is a 14x19 the 5 star is a porsche 911 11x18
Discussion Starter #89
car had to come out of the shop but it got us a chance to see it real low, were looking for 5 inches of TOTAL ground clearance from the lowwest point, also visited larger headlights, and pre- sheered a rear quarter panel down in preperation of wide body
Nice, Lotta Rubber
You made my day Sh0rtlife which otherwise was crappy! Fantastic pics, thanks for sharing - you've some mad skillset which makes me jealous. It will be hell of a car when you're finished :)
Discussion Starter #93
heres a slight step back in the time line..a mock of the suspension and some rough guess wheels, this was just after picking the slc but before finding one, but ive been sitting on the suspension 6 years?
Discussion Starter #94
ive been sitting on a set of wheels for a 911 a buddy gave me not long before we lost him to cancer, he helped us thru another build as well, funny and fitting he is helping us still with parts and stuff he sent me over the years, never thought id find a use for these wheels, couldnt sell em, ....
took em apart and managed to make a mock up 19x14 barrel for that 345 thats on its way from summit
between the barrels n shells ive got 2 7 shells, 2 6 shells, 2 4.5 faces, 2 3 faces, making for a nice combination of test 19s to make sure we order the right size wheels
so forgive any current tire/wheel you see as they are purely mockup, ill let you know when the tires arrive , however i have all the sizes and number covered so i can mock on the fly to figure out placement, fitment, offset, cuts, clearance etc etc etc
on a side note, fronts have change from 18 to 19 due to a backorder till OCTOBER?!?!?!!?!?
back in the shop, blocking and testing for correct stance
I think you've enough materials sh0rtlife to turn this into a TV show on Netflix :D
Discussion Starter #96
these will look like the same shots but they are not, note the blocks, ground clearance stance check, 3inch, 4inch, 5inch
5
4
3
Discussion Starter #97
single posting these is a huge pain and imgur isnt maintaining order, we settled on 4 front 5 rear at rocker jack edge, imgur order is 5, 3, 4, just as a referance(just note the blocks)
Discussion Starter #98
now, remember im building a wide body, these cuts are un-important and only for visual referance and verification of tire sizes, what you see hanging out of the body WILL be covered with new body, so take the shots knowing this will be the new line way out here, and the old body will get cut even more for clearance
Discussion Starter #100
i am rather impressed at how well a big tire could be made to fit with little effort, heres a 305 19 wedged in after the cut, note the fit
