Pardon me, but what are resonators? If that is causing the crappy noise, I get rid of them! I want to hear a rumble or some other noise (What sound does a true V12 make)? I love the 500E's engine sound!I think you need a custom exhaust with no resonators, just mufflers. If you have a V12, you should hear it sing.
You actually can't turn off the ASR, I've tried. You can suspend it by hitting the button that has a picture of a tire with chains on it. Its made for letting the tires slip up to 25mph to get traction when using chains in the snow. Unfortunately, and kinda stupid, the ASR is incorporated into the whole throttle assembly, so you can't remove it and have the car run. If it was possible, I would have done it immediately :^).
I've seen w140s with two mufflers, one per side. The quad pipes are just 1 into 2 tips, so its a single pipe tip, with two tips on it, much like the stuff you can find for $40 at your local Schmucks. There is a Brabus S600 cruising around in Seattle I see every now and then, and it has a single muffler in the stock location, with tips pointing sideways, like the BMW e30s. I didn't much like it.
If you think the 6.0L sings, you should hear the sound of the 7.4L[I think you need a custom exhaust with no resonators, just mufflers. If you have a V12, you should hear it sing.
If you think the 6.0L sings, you should hear the sound of the 7.4L[I think you need a custom exhaust with no resonators, just mufflers. If you have a V12, you should hear it sing.]
http://boykinracing.us/applications.htm
Hey, just because I love Audi, doesn't mean I don't respect the brand. I work on benzes on a biweekly basis, and truthfully I'm beginning to fall in love with the W220. But, until I can figure out a way to put a M120 7.4L into the chassis, I don't think I'll be getting a benz anytime soon;-)TROLL ALERT, Non MB owner trying to stir up trouble. ;-)
Are you referring to me? I do have a 600SEL. Hey Dual 5L, I didn't know that that the Snow tire switch turns ASR off till 25MPH. I'll try and get some wheel spin. With ASR on, you can get a little before the triangle flashes and ASR intervienes. Do you thinks changing the tire width will slow the intervention of ASR?
