Ok I'm trying to put the hood cable back in and can't figure out how the thing goes in.I know the path it takes and how each end goes on but the problem is that the cable passes threw the core support and the hole is only a little bigger than the cable.Which end comes off and how?
1965 220S, 1999 Volvo V70 (wagon), 2006 Ford Crown Vic Police Interceptor, 72 350SL 4 Speed
W111 Fintail or Ponton?
I Had already taken the handel off and it stil didn't fit.The I figured out the
problem at some point some one put a new core support in and the hole in the support was to small.All the other cars like this one we have here have a larger hole to allow the end with the handel(handle removed) to slide threw.
Drilled the hole to the correct size and the cable when't right in.
