1988 560SL
My 88 560SL has a slight high idle -- ideas for possible cause? And should I be overly concerned (not excesively high, only slight).
1997 SL500- 40th Anniversary
Your description is woefully inadequate for us to be of any help. What is th erpm at idle? Same hot as cold? Anything done recently to cause a change?
I realized I never got back to this thread... Below is a link to the influencing factors of the CIS-E idle control for the 560.
http://www.startekinfo.com/StarTek/outside/11883/PROGRAM/Engine/107/M117_56/073-009.pdf
#1- Look for vacuum leak... Then move on down the line toward other factors listed in the attachment in the previous post. If you do not have a manual, link to the online manual in the Egv107, and navigate to the CIS-E control section. 07.3...
