It appears that the power antenna on this 86 5690sl is not completely finishing...it leaves about 6 inches. It doesn't completely disappear. <br>Is there a way lubricate this? It will go all the way in if i physically push it down..It just seems like it is too tight for it to go on the own...will WD work?<br>Please reply to [email protected]<br>Thanks,
Discussion Starter #2
I currently own a 1988 560SL that experiences the exact same thing from time to time. I use WD-40 sprayed onto a rag to clean and lubricate the antenna every other month. Since then, I have not had a problem with the power antenna retracting flush into the hole.
CHECK ENGINE LIGHT
CAN ANYONE SHOW ME HOW TO REPLACE CHECK ENGINE LIGHT BULK DO I HAVE TO REMOVE THE DASHBOARD TO CHANGE THE LIGHT...
CHECK ENGINE LIGHT
