I have an 87 560SL. Is the electric fan supposed to come on when the a/c is turned on, or is it only activated by temperature?
thanks
Fred Emmerich
thanks
Fred Emmerich
interesting...thanks Ears..and I meant C not F in my post....Well, let's see what the FSM sez...
Not quite as settled as implied... "Min" also sets the compressor to full "on", and takes the temp control out of the loop (as does "max" when heating, no temp control) as well as set the fan to step 5. See the manual linked in the thread referenced here...That pretty much settles that, thanks.
Nope...If you have to replace the fan switch (the one that turns the fan on with the a/c), can you remove it without losing pressure in the system?
Fred Emmerich
thanks for the info Ears...my problem is:Not quite as settled as implied... "Min" also sets the compressor to full "on", and takes the temp control out of the loop (as does "max" when heating, no temp control) as well as set the fan to step 5. See the manual linked in the thread referenced here...
http://www.benzworld.org/forums/16224530-post13.html
No increase in load or a different compressor "gear" or output. It just doesn't cycle according to the climate control temp (stays on more like a conventional air compressor system). I'd have to research if there is any fuel enrichment or otherwise that also occurs... I'll leave that to you. Someone here has a full climate control system manual I recall. Otherwise a fairly good read is in the regular FSM. A full diagnostic of the system is in order, ie is the charge quantity and type correct, is the compressor in good nic, etc...thanks for the info Ears...my problem is:
Temp wheel min( not detent)...acceleration from stop is great
Temp wheel min...in the detent...car stalls out
When you say "Min" also sets the compressor to full "on", I'm assuming you mean going from Min to Min in the detent, it's kicking up the compressor up a notch..if true, that's probably causing my stall from stop by increasing load...any thoughts on how to correct this ?... engine RPM's appear normal in all situations...
Harv
thanks once again for the reply Ears...had new compressor installed about 10 yrs ago along with all components when I converted to R134.. last year evacuated and refilled with R134...blows great cold air...your comment on fuel enrichment in the detent min position has me thinking....will do more research and let you know....have a happy and safe 4th...No increase in load or a different compressor "gear" or output. It just doesn't cycle according to the climate control temp (stays on more like a conventional air compressor system). I'd have to research if there is any fuel enrichment or otherwise that also occurs... I'll leave that to you. Someone here has a full climate control system manual I recall. Otherwise a fairly good read is in the regular FSM. A full diagnostic of the system is in order, ie is the charge quantity and type correct, is the compressor in good nic, etc...
