Mercedes Benz 1987 300SEL
Pretty sure these cars have a natural delay from when you stomp your foot down till they go, they are not super responsive cars.
It also could be your kickdown switch.
Could be your tranny too.
MB 420SEL 1986-Bought in 2010, MERCURY VELLAGER-1995, NISSAN MAXIMA 1996, Buick Lesabre 1995
When I push down, there's kind of a fast and light chugging sensation, and then the motor picks up. Could this be caused by a leaking intake manifold?
Check the fuel pressure at the fuel distributor. It should be more than 90 psi. No harm in changing the fuel filter first. Make sure both fuel pump are operating normally.
Sahai
Mercedes Benz
I found this thread trolling for something else:
Speaking for a 1985 380SE-
Most of the above is all true.
ALWAYS begin any trouble shooting on a car that IS PROPERLY TUNED-UP by first checking vacuum lines and boots for wear, brittleness and leaks. There are two lines that are under the plenum (standing at the front of the car facing the engine- behind the idle control valve) that go to a thermo switch at the passenger head bank. They can be a bear to get to without removing the plenum/ intake.
Once I had a bad hesitation. It was the t-junction vacuum that also connects to the switch that is on the outside of the coolant reservoir.
Second- you must perform a fuel pressure test. There are plenty of strings that go over that. THE SLIGHTEST leak in the system will cause problem. For example, I once had a crush washer between the fuel pump and the aperture that was very slightly diminished by sodium chloride. The damage caused pitting and an air hole that cause hesitation on acceleration.
Welcome all to owning a old Mercedes. ALL THINGS OLD NEED MEDICARE- in this case, Mercedes-care.
