Hi guys,
New to the forum.
Recently bought an 89 /560 SEL.
Happy with the car except rear suspension.
The previous owner deleted the SLS suspension but now the car is low and uneven. I have been reading the posts on the forum and is obvious the job was done sloppy and incorrect.
I suspect new regular socks were installed but same old springs were used. The lines were cut. No apparent leaks under the car. The pump is still there and there is still fluid in the in the glass tank. The steering is harder than expected( now I am learning that SLS pump also operates the power steering).
I was optimistic after finding that this conversion is common, and the problem can be fixed.
The problem is finding a mechanic to do it. I was turned down by at least 4 shops that specialized in German cars ( they did not even look at the car).
The all claim there is not just replacing the springs/shocks and using shims.
I was planning to buy new Blistein spring/shocks .
Do you guys think they don’t know how to do it or is too much trouble for them? If Anyboby will take on this job, what would be reasonable to pay for it? The parts are not expensive.
I live in Wilmington DE/ close to Philly.
Please advise.
Thank you.
New to the forum.
Please advise.
Thank you.
