1986 560sl
I recently purchased a 1986 560 sl.the problem is i have only high fan speed.no low or auto fan.the mono valve and aux water pump have been changed.the air conditioning does not work.advice would be appreciated
Administratoris Emeritus
2024 SL770
Welcome to BenzWorld! I'll slide your query down to the R107 section, where you're far more likely to garner a helpful response from some like-minded enthusiasts. You might also consider completing your user profile, many find that information helpful in regard to providing you with the best possible response.
1997 SL500- 40th Anniversary
Ron,
Thanks for the re-direct. He's ours now!
560slvictoria,
I would recommend you first check out the sticky at the top of the 107 forum, titled "This Damned Old Car...". You will need to review the section on climate control. Then, you will likely be able to zero-in on the issue(s)
Welcome!
